General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
If the bars are a consistent diameter, which will allow for the controls to slide closer to the middle, it should be no problem. But if you have large diameter bars, the "step" in the bar would prevent the controls from moving. Post up a pic of your bars. With 1" bars I have done that in the past, took about 2" off each end on a Sportster, worked out great. Good luck.
