Gas tank liner problem
Old Jan 25, 2012 | 03:26 PM
mrknish14's Avatar
mrknish14
Stage III
Default Gas tank liner problem
I have a 72 flh that one tank had a liner previously. It sat for 12 years empty and now the tank is rusted inside under the liner. I have tried chemicals (mek, thiners, denatured alcohol), Nuts and bolts and shaking it around, rocks, everything I can think of. I got 90% out with a airgun but the other 10 percent is causing me hell with the carb. Flakes of rust are getting into the jets and clogging them. I have cleaned the bowl and petcock screen but would like to get all the rust out of the tank. Any Ideas?
Old Jan 25, 2012 | 05:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
POR 15 will get that crap out, including the old liner.
http://www.por15.com/CYCLE-TANK-REPA...ductinfo/CTRK/
Old Jan 25, 2012 | 05:40 PM
j1mmy's Avatar
j1mmy
it had to be a bad diy project.. you could always get it relined. the chemicals that they use eat through rust and old liner material. then use cream tank liner or a radiator shop has a red liner they put in. it is good, you will never have another problem..
a good fuel filter is always good to use too. you might have to get creative with a longer fuel line to make it fit..
805dwg
General Topics/Tech Tips
Jun 23, 2024 12:12 PM
Jacoblb
Nov 25, 2012 02:41 PM
hk1990
Sep 9, 2011 02:48 PM
motordrum
Exhaust System Topics
Dec 27, 2010 11:24 PM
Susie B
Sep 16, 2009 10:06 AM
