Easier clutch pull for TriGlide?
My wife will be riding her 2010 TG before too long (unfortunately it currently sits in the garage while her collarbone heals!). She's left handed, so that helps, but she is a petite lady and I am wondering about the clutch pull. I rode about 90 miles and it is a good bit stronger than my '09 Heritage clutch pull, although for me it wouldn't be a problem. Anyone hear of an easy pull alternative to the stock clutch. I realize its a 103 with a lot more weight to pull compared to my Heritage, but I was just curious whether anyone else has heard anything or given any thought to the clutch pull. I really don't know yet whether she will think it's an issue, but I could see a problem for her wearing out in stop and go traffic.
I have small hands and the clutch was hard for me. I did get used to it, but just couldn't hold it at lights for a long time without feeling the pain of arthritis kicking up. Even hubby had a hard time when he rode it at Daytona Bike week with all the stop and go. In fact, he is the one that went to every vendor inquiring about what could be done. I did find out eventually about Variable Pressure CLutch and ordered one. It reduces the pull about 20% and I am happy with it. Mr. Wizzard here on the forum knows where to get them.
Depending on which one you get could reduce your lever pull from 20 to 40%. This is also dependent on which spring set up and motor you have now. There are only three to choose from and it's easy to use the factory chart to pick the right one for your combination.
A stock clutch set up pushes the clutch spring from the outer edges of the spring. A VPC will push the spring from the inner edges where there is more leverage thus an easier pull on your clutch lever. This is shown on their web site. By using centrifugal force, the VPC will increase your clutch lock up force by about 40% within the higher RPM ranges. A VPC will also make it easier to find that illusive neutral light.
Here is the web site. The VP84T, Up To 103" motor, is what the majority of us have already installed and can be easily done at home directly though the derby cover with no fluid loss.
Personally I have a SE spring installed and the lever was fairly heavy, about 40 pounds of pull, but after installing the VPC it is back to a normal pull weight now. I couldn't imagine the pull if I didn't have the SE spring in there too. Would be like grabbing air. Next time I break down my primary I will remove the SE spring.. don't need it with a VPC.
Cheers
(Awhile back I mentioned 'easy grip' clutch/brake levers....well, tried to pull in clutch, had to use both hands and still wouldn't engage. Back to the dealer for refund and had my stock levers put back on yesterday....$$ grrrr.)
I installed the Easyboy Lite (White Bros.) on my '05 Road Glide clutch cable actuator several years back and it has worked like a charm. But it works in a different manner and I don't know if it applies to the newer models. It was also a bit more complicated to install though. Had to drain trans oil, remove housing, and install new gasket.
