blue gold colored pipes
hello,
have noticed my pipes are turning a blue gold color up by where they go into the cylinders. on the older bikes this was a sign of a lean condition and i am wondering if anyone else is experiencing this? the trike is stock for now but i intend on having the stage 1 installed at the 1k service.
david
socal
david
socal
hello,
david
socal
david
socal
Note: even with a proper tune you can't keep stock head pipes from turning color but they will turn color faster and further down the pipe when you are lean. Some mufflers will turn blue at the front exhaust neck especially if the baffle or baffle wrapping material is removed.
One of the perils of riding the thing! If you want it to be showroom pretty, don't start it, just stare at it. If you are a rider,as it appears that you are, then just accept it. I don't care what you do, you can't keep them completely shiny unless you don't ride them. Which do you want, pretty or wind in your face?????????????
Don't want to sound like some jerk but you can't have it both ways. When you build a fire in it, it is going to cause some bluing.
Ride it like you stole it and have fun--too hell with the ones that only want "pretty".
pretty has really never been an issue with me. road an old beat up 74" for a number of years. i am concerned about how hot this trike may be running and will discuss this with the tech at the 1k service.
with the 74 inch i could beat the hell out of it and still run, had the normal issues that were expected with the AMF bikes but did like the thing.
really like this trike now that i am older and wiser and just wanting it to be fine after dropping 34k on the thing.
will get the stage 1 and ECM download at the 1k service and from what i read this should help with the heat issues.
thanks,
david
socal
thanks,
david
socal
On the right track
thanks,
david
socal
thanks,
david
socal
I am not sure how much benefit we will get from a Stage I with a Cat, will have to ask a CVO guy I guess they have had them for awhile, plus the Cali bikes. They seem to be fairly free flowing pipes on the 2010's but some guys are reporting them glowing at night from the heat. Big discussion on another forum weather to lose the cat or not.
I love the old school post on reading the plugs, right on the money. Pull that rear cylinder plug and see if the center ceramic on the electrode is chalky white, brownish, or black sooty. After the tune if the chalky white turns to a redish brown you have it dialed it. A good cool AFR. I installed a Jag 10 row oil cooler and a Lenale fan until I get the catless pipe or gut the original. This won't help with discolored pipes but trying to do some bandaid stuff until I get the fix put on it.
thanks,
david
socal
thanks,
david
socal
Don't blame you for wanting to protect your investment. We have 34K in a '01 Fatboy with a DFT kit on it. Hope everyone gets the heat issue handled soon. Enjoy the trike, we do!
Get it tuned; both fuel and timing (map).
If you really feel you need to correct the discoloration, try "blue job," or, if you really can't stand the bluing, either wrap your pipes or try ceramic coating or jet coating.
All in all though, I agree with Kentuckydave; ' just ride it.'
Better a dirty day on the road, than a clean day in the garage,
roll on
-l
roll on
-l
The stage 1 may help but it is by no means a fix.
