Screamin Eagle orange 10mm phat spark plug
i just installed the orange 10mm phat wires and used the grease that came with them on the inside of the boot. they must be available in canada as i ordered them on a friday and they came in on Tuesday. everything went great
https://www.hdforums.com/forum/gener...g-wires-2.html
Update install review
Hello Street Fans,
I just got finished installing the new HD Orange 10mm Phat Spark Plug wires.
Install time 3 minutes. I used a Qtip to apply the dielectric grease to the boots.
(Grease came with the wires). I did not use the zip ties that came in the box to hold the rear wire. The factory clips are holding the new Phat wire. I had to bend the front boot to the front cyclinder and it was a tight fit to get it in the hole. Overall, it was easy and looks great. The orange looks great against the black denim. The length was perfect. I did not have to remove the seat as per the instructions. I fired up the 500 ...everything seems fine. We just got 2 feet of snow and are looking for more so no test ride. Just a quick update.
Weshi-cat-welo
Weshi-cat-welo
