This Street Rod is a hoot!!
whats the difference in the Street and the XG other than price? I think the Street has a stage 1 upgrade?
The Street Rod's engine produces more power and flows better; it performs stock about like a Street 750 would if the Street 750 had a Stage 1 upgrade put on it. But the Street Rod has a bigger tire on it, which changes the net gearing to make it taller, so in a drag race they're similar. Cycle World tested both of them, they put the 0-60 on the Street 750 at 4.6 and the Street Rod at 4.5. Harley's specs call for the Street 750 to produce 44.5 ft/lbs at the crank, and the Street Rod is 47.9, both at 4000 RPM.
The Street Rod is pretty much universally praised for having a higher quality fit 'n' finish; there were complaints about the "cheapness" of the Street 750 (exposed wiring, visible welds, etc). I don't know if that's still the case or not, but it certainly was at the introduction of the Street 750. The big complaint on the Street 750 was the brakes, although those were addressed/upgraded on the 2016 models, and the 2017 now has ABS as an option, so I don't think that's really an issue anymore. As for the Street Rod, pretty much the only big complaint I've read is the riding position; one guy referred to it as that it turns you into a "toad"; laying flat over your arms while your legs are bunched up under you. There were complaints about the footpeg position, etc. But most reviews praised it for performance and build quality.
So -- if the seat is too tall, or the riding position isn't comfortable, then the Street Rod's not for you. But if you're comfortable on it, the Street Rod is better built and better performing. Really you have to try them out, the seating position is so different that that alone might make up your mind between the two.
Yep, I sat on a 750 the other day during my lunch hour and I felt cramped. I'm 6' around 180....seems the bike was not a good fit for me, but I like the style of it. Maybe one of these new names HD has patented. (Bronx, or 48X) will be another street bike design instead of another cruiser?
If you're going to buy a Harley then buy a big Harley. If you're going to buy a sport bike then buy one of the jappers. They're cheaper, faster and probably more reliable. In any case there's most likely a whole lot more performance parts available for them. I'm just sayin'.
I don't think it's a hate thing with Sportsters. I just don't think most Harley riders see the sense in them.
Received 5,388 Likes
Very surprised that the radiator "guard" would make so much of a difference with regards to the sideview, but, it certainly does.
I think once the fuel/spark/timing curve are optimized, you won't have to answer, "How's the low-end torque?"
I'm more interested in the "topend rush" personally.
