Removing Catalytic Converter Honeycomb
Little advice the Bassani pipe for the Street really sucks, loud and just does not sound good. One in the bad idea box down stairs.
Have you seen the exhaust on a Street Rod? 2-into1 and that it what I prefer. Plus, the cat is in the header just past where they come together and right before the can.
I chatted with V&H's yesterday and it seems there is a full exhaust in the works for the Street Rod. No timeline for release as of yet.
Received 5,388 Likes
To put it very simply, the performance changes would likely be minimal, unless cams/headwork and induction were optimized.
The catcon does offer some noise reduction. As you know, the chemical reaction does produce heat as a byproduct.
Are you familiar with "stepped tube" headers?
The larger diameter slows the flow of gasses a critical distance from the exhaust valve. This "slowing of gasses" helps scavenge the cylinder of spent gasses on the following exhaust stroke. This allows more fuel to enter the cylinder to be burned on the next "power" stroke because the cylinder is virtually "vacuumed" of spent (now inert) gasses.
This effect can certainly have a positive effect on torque if optimized. Not talking 15%-20% increase here. More like 2% or 3%. But, it IS an increase over "non-stepped tube" headers.
A stepped header design would be good for maintaining the torque output of the 750. None of the major players offer up a full exhaust as of yet. The cat chamber is back by where the muffler joins in the party. Maybe I'm making a bigger deal out of this then need be but I don't want to loose power just for lower exhaust heat. The area circled in red in the picture below is the area I am concerned with.
Not sure what you are getting at with that comment. I know where it is and the many ways to remove the honeycomb. I'm more concerned with introducing the open larger diameter chamber to the exhaust flow where the converter would have resided. I don't want to create a bottleneck in the flow. The set up on the Street series is different than the BT's.
You would be better off spending the thousand if you’re that confused.
Even on my touring bikes going to a performance header to remove the CAT No noticeable difference. You would have to put it on a DYNO to find any and even then so little it is meaningless. Wanting to believe the money you spent made a major difference just justifies the cost but it your fooling your self. Spent to many hours messing with it, then doing a dyno run to see the difference.
