I'm rebuilding a flooded XL1200C
@monkeyboy22 I used the WD40 specialist contact cleaner. Most of it wiped off with just a dry towel but used the contact cleaner to clean it up a bit more.
So long as it wasn't in too deep and water didn't enter the engine I would take the plugs out and see what happens when you turn it over.
This is draw back with the HD engine that there is no engine drain plug to see if there is water in the oil.
If just cranking can get the oil back into the tank that will tell you all you need to know.
An engine that hasn't run for a while will not drain the oil out as it will be in the sump.
QRUCK (12-03-2018)
QRUCK (12-03-2018)
I would definitely drain the sump...
battery isn't charging
QRUCK (12-03-2018)
