No spark 2005 heritage
Old 10-22-2015, 07:43 PM
Regan1000's Avatar
Regan1000
Regan1000 is offline
Stage II
Default No spark 2005 heritage
I need help with diagnosing my no spark problem. Bike is a carbed 05 heritage.
My problem is the bike was running fine then pulled the tank and guards off to paint put them, put back on bike fired up and ran really rough for 10min or so then died completely. Checked spark plugs for spark, was none
swapped the coil,plugs,leads, and the ignition module off a bike that is running still no spark.
CPS is giving a pulse to the ignition module but no pulse is comming out of the IM to AB terminals of the coil therefore no spark.
CKP sensor is putting out an AC voltage so I assume is ok.
Can anyone shed some light on what would be stopping the signal leaving the IM?
Old 10-24-2015, 04:29 PM
JustDave13's Avatar
JustDave13
JustDave13 is offline
Received 15,090 Likes on 6,141 Posts
Pull the tank and check your wiring, you may have pinched one during the tank installation.
Old 10-24-2015, 07:03 PM
Regan1000's Avatar
Regan1000
Stage II
Yep in the process of checking the loom now. Just seems weird that it ran after I installed the tanks for 10min and just slowly ran worse until the spark died completely
Jiggyj96
06-01-2017 10:26 PM
txphatboy
10-06-2015 08:07 PM
tugboatlife
05-19-2014 06:31 PM
Iron Man73
Ironhead
14
09-30-2013 08:44 PM
sidways
08-06-2012 10:40 PM
Quick Reply: No spark 2005 heritage
