Help!!!!
Old Nov 2, 2016 | 01:54 PM
Ultraclassic chris's Avatar
Ultraclassic chris
Stage IV
Default Help!!!!
I have a 99 Ultra Classic I put a new stator in it. the motorcycle over charged ,the volts ran past 16 and blew every fuse in the Box.(i know how to fix that problem) I replace the fuses and the relays.but it wont start the fuel pump doent kick on the radio wont come on and i have no spark.anyone ever had this problem or have an idea of how to fix it?HELP
Old Nov 2, 2016 | 02:00 PM
MURPHCC1's Avatar
MURPHCC1
Chris, do you have a service manual?
An Electrical Diagnostics manual?
These are two of the basics if you can turn a wrench and follow schematics.
Old Nov 2, 2016 | 03:04 PM
Garrman's Avatar
Garrman
Hey Chris,
One simple thing to check. Look to the front of the battery compartment and locate the main breaker. If you have a volt meter, run a continuity check to make sure it's still good. If bad, it's about $10.00 at your local dealer and probably less at an auto parts store.
Good luck and let us know what you find.
Garrman
Old Nov 2, 2016 | 07:24 PM
Big Dave's Avatar
Big Dave
Also change the voltage regulator before trying to start it again
Dave
Old Nov 2, 2016 | 09:27 PM
FLTRI17's Avatar
FLTRI17
The stator and rotor produce unregulated voltage and will take out electrics and electronics if it is let to run amok.
It is the voltage regulator that controls the voltage to the bike.
I believe you have 2 issues. Fix the charging system.
Look to the main breaker/wiring to be the source for all systems failure.
Guess it's possible the over voltage took out you ignition switch?
HTH, Bob
Old Nov 3, 2016 | 07:40 AM
Garrman's Avatar
Garrman
Sage advice from Dave and Bob. I got so focused on the loss of electrical that I overlooked the voltage regulator.
If the VR/main breaker/wiring check do not resolve the problem, troubleshooting the ignition switch can be done with a continuity (volt meter) checker.
Good luck.
Garrman
leadman
Oct 6, 2014 05:57 AM
tonemachine
Electrical/Lighting/Alarm
Sep 8, 2014 09:18 AM
lovethemhogs
Ironhead
Sep 17, 2008 07:14 PM
Boogie Knights
May 16, 2006 02:49 AM
herbdon
Exhaust System Topics
Aug 15, 2005 06:36 PM
