FLT2004 ignition to FXSTB 2004
Old 07-11-2017, 08:49 AM
Strannix's Avatar
Strannix
Strannix is offline
3rd Gear
Default FLT2004 ignition to FXSTB 2004
Hello everybody. What is the differences between the HD FLT ignition system and HD FXSTB ignition system. I have a SE ignition module for the FLT model. Can I set it on FXSTB. Bikes were born in 2004, and both are carbed. Thanks!
Old 07-12-2017, 05:27 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
If you check on-line here you will find that stock those two bikes both use the same ignition module, so it seems reasonable to assume that the SE module should work. If you really are in Russia it seems appropriate to try!
Old 08-02-2017, 02:47 PM
Strannix's Avatar
Strannix
Strannix is offline
3rd Gear
Yes, I'm really in Russia. I've set the FLT ignition module and it works!!! I've made initialization manipulation two times.
Old 08-02-2017, 03:56 PM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Great news!
Old 08-03-2017, 10:03 AM
Strannix's Avatar
Strannix
Strannix is offline
3rd Gear
Great news!
rouskie
Ironhead
03-20-2017 10:14 PM
Schulte94
Evo Era Parts
11-10-2013 11:38 PM
gabarnes28
09-29-2010 06:19 PM
Booey424
09-27-2007 07:40 PM
rhinoevans
08-24-2005 03:09 PM
Quick Reply: FLT2004 ignition to FXSTB 2004
