I Think I Have Decided on a Fuel Programmer
I was just at your crossroad. Research buy once and save money.
Important Notes:
Fuelpak FP3 requires a user supplied iOS or Android based unit such as a smartphone or tablet which is not included with purchase.
FuelPak FP3 is a flashed based tuner which gives you basic control of fuel & spark. This product is best suited to Stage 1 modifications such as air cleaner & exhaust. FuelPak FP3 does not support modifications such as aftermarket cams or big bore kits.
FuelPak FP3 maps are developed by V&H exclusively based on exhaust systems manufactured by V&H.
FuelPak FP3 does not use a software suite for computer use, all tuning is done via smartphone or tablet.
FuelPak FP3 marries to a single bike, this product cannot be unmarried, relicensed or used on another bike
Important Notes:
Gary,
If you are selling widgets and I call and ask do you have the right widget for me, what would you tell me? Also consider if in the future you need a dyno tune you will need to buy a tuner they can dyno and the FP3 is not one. The Power vision can be used to dyno the bike. I did a lot of research it cost me a few hours and an 12 pack. Not trying to bust your chops but it seems you picked the product before research and then see if it will work. Call a tuner that sells many products tell them what your plans are and ask what is the best option. Good luck and enjoy that M8.
Every tuner I talk to in the industry either via phone, forums or private tuner FB groups will all tell you to stay away from the FP3. It's junk.
TTS
Vision
TR
SE
In that order. The big dot com store that sells Vision and says it is the best. Lost their privilege to sell TTS. So, you can understand why they push every other tuner so hard.
Customer service. Dealing with all of them. I can't say one is better than the other as for as effort. Some of their downfall is because they are trying to support a third party product while some are supporting their own. Obviously the problems I am talking about go a bit deeper than. How to use product to map the VE's?
TTS
Vision
TR
SE
Fireball Jack (01-25-2018)
Originally Posted by Fireball Jack
Gary,
This and I have an FP3.
