2005 ultra classic S&S .509 cams power vision map
No matter which base map you start with it will, for sure, need proper tuning to get the mixture of parts to work well together.
There are no canned maps that will be close enough that a dyno tune will not be necessary to get smoothness, response, and great mileage.
Other than that, you can convert your bike to late-model closed loop operation, which is by far the best solution IMO. Then use TTS V-tune to calibrate your fueling.
So, IMO, take your bike to a qualified tuner and get it tuned properly.
OR
Convert your bike to closed loop operation, read and absorb V-tuning procedures, and do it yourself.
Bob
OR
Bob
OR
Bob
OR
Bob
If you’re up to spend some more $$$ (exhaust mods and extra tuning hardware) AND take the time to read/reread the PV manual (need link) until you have a clear understanding of what happens and how to get the end product (great running bike) you want, go for it.
Otherwise find the right tuner and go with what he wants and you’ll end up a happy camper without having the frustration from spending the money, studying the manuals and forums, plus the trials and errors from learning curve... just to get the bike running right.
Bob
Bob
Dyno jets site says that target tune is not available for my 05 just auto tune pro. I'll be running power tune duals which are set up with 18mm bungs.
As long as the OP is staying stock 88/stage 1, a properly picked canned map will usually provide an acceptable running bike.
Start adding cams, compression, porting, exhaust design change and it will be exceedingly difficult to find a canned map that will provide even a “decent” running bike.
So upgrade the system to the later closed loop with O2 sensors and learn how to street tune your bike. Without the O2 sensor system you will have no help in knowing where to make changes and easily get lost trying to figure out where to do what and when.
Bob
Bob
