How to test fuel pressure on a 2000 MM EFI system?
Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Did the fuel fittings change at all when I Harley switched from MM fuel injection to Delphi? Do I need to buy a different tester for the MM or will one for the later delphi's work?
any ideas on how to do this at home without spending an arm and a leg could be appreciated
remove the allen plug from the bottom of the stock MM fitting, install an andapter to fit your fuel pressure guage, ps, its pipe thread into the fitting. then test as usual and compare specs to the book.
m
ps, just had to recently do this myself, so i know that it works.
