Burnt 2015 freewheeler
Is the ECM and BCM still good ? This bike has the BCM module and i don't think it would perform correctly without the proper wiring harness. There are very touchy to how long the wires are and the size of them. You may be money ahead to just buy the factory harness and be done with it. You could bypass the factory stuff and if you can get it to run you could always wire the lights and other stuff up. Good luck with your project.
58Dgrizz
02-26-2012 02:14 PM
