Having problems with the Sert & VISTA??? SOLUTION!
Hey, guys! Here is the solution to using the Sert with Vista. You must install the XP operating system on your machine. Simply install the XP program. Your machine WILL operate on Vista, however; you will also have all the benefits of the XP program. Your microsoft software ( ie.. Word, Exel, etc.) will operate. This process will mesh XP with the Vista. Install the full program OVER the Vista. This will take up some space on your drive but, the results are INCREDIBLE!!! If you need help, just blog ore-mail me @ dsakowicz@sbcglobal.net.
RE: Having problems with the Sert & VISTA??? SOLUTION!
Vista is garbage. I bought 2 new laptops for my wife and daughter and after 2 months I have reformatted them and did a clean install of XP. They run twice as fast then with Vista and all programs work like they should. Only problem I ran into is I had to disable the sata in the bios to install a "legacy OS" otherwise it won't work. Beyond that Vista can kiss my a**.
Wheelup
09-08-2010 06:39 PM
waterman7474
01-06-2007 05:08 AM
