sert bummed
Old Dec 4, 2007 | 03:41 PM
wrenchbendr's Avatar
wrenchbendr
Default sert bummed
after much thought i decided to not use my fuelpack and get the sert. went to purchase the sert from my local dealer and found out that the tuner only works on computer os's up to xp not vista! anyone know what to do now other than wipe out my os or buy another cheap computer? anyone install the sert software on a vista system? thanks!
Old Dec 4, 2007 | 03:55 PM
mud's Avatar
mud
Default RE: sert bummed
ORIGINAL: wrenchbendr
bendr, pick up a cheap PC.
Make sure it has enough memory etc.
Put it in the garage.
I hear that Vista is not compatible with a lot of the older software.
mud
Old Dec 4, 2007 | 04:17 PM
SPECIAL ED's Avatar
SPECIAL ED
Have you tried to install it on Vista? I doubt it will hurt anything to try.If that doesn't work pick up a cheap computer or even a spare OS and set it up to multi boot.You don't have any friends with an old laptop?When I got my laptop I got an option of getting a free Vista upgrade, I still haven't felt the urge to run down to Best Buy and pick that up.
Old Dec 4, 2007 | 06:58 PM
wrenchbendr
special ed, no i haven't purchased it yet. i put the brakes on buying it today when on the very last line of the add said "not for windows vista". although it said that i was wondering if anyone else here has tried to use it on vista?
Old Dec 4, 2007 | 08:06 PM
grandpawmoses's Avatar
grandpawmoses
Search down in the "Electrical/Ignition/Tuner/Ecu/etc" forum. I believe it was discussed and someone had a work around using Vista. I didn't soak it in cause I ain't got no Vista.
David
Old Dec 4, 2007 | 08:19 PM
dklozik's Avatar
dklozik
You know how cheap you can pick up a used laptop at a pawn shop ? Get one for just the garage, under a $100. Problem solved.
Old Dec 5, 2007 | 01:24 AM
sofus's Avatar
sofus
How about running XP on Microsoft Virtual PC?
You can download it from Microsoft. It's free.
Another alternative is VMware Workstation. It has better support for network and more than Virtual PC.
I have both Virtual PC an VMware on my laptop. Main OS is XP and Irun Vista and Server 2003 as aditionaloperating systems with no problems. I'm about to get a new laptop with Vista as mainOS and then I'll run XPand Server 2003 in Virtual PC or VMware (have to find out whichcombination that works best).
classic53
Jul 6, 2011 07:50 PM
Spanish Flyer
Jan 15, 2008 07:01 AM
RCopeland1
Aug 27, 2007 06:22 PM
ebeattie
11
Jul 21, 2007 10:45 PM
SPECIAL ED
Sep 3, 2006 04:26 AM
