FP3 failure/error
FP3 failure/error
Gave up on this 6 weeks ago, I have gone through all the correct installation procedures and had a replacement sent from Vance and Hines with the same results. I don’t think it will ever link to my bike but I would really like to know what the problem is. I haven’t a clue, V@H don’t know what the error code means. This is not a ‘dig’ at V@H as most people are happy with the product. I’ve just got an itch that I can’t stop scratching
Tim F (06-19-2019)
Have you looked at your connections ? The plug that plugs into the FP3 could be corroded or maybe has a broken pin/wire inside the connector housing . Check those connections as well as the ecm connector . Using some contact cleaner might help . Not sure , but worth a shot .
I would expect that if a unit is throwing up an error code, someone who designed it programmed in these codes and must know what they mean.
Thanks for the suggestion, I have checked out the connections and they all seem ok .The FP3 sends information back to my phone such as revs, temperature etc but won’t link permanently to load a map.
Bryan
