Thundermax ECM without O2-Sensors
Old 11-24-2022, 06:37 AM
sepperl's Avatar
sepperl
sepperl is offline
Default Thundermax ECM without O2-Sensors
Hi all,
I have a 04 Fat-Boy on the bench that needs a new ECM.
I have the Thundermax EXM Wave Tune ready for install.
Since the bike does not have O2-Sensor-Bungs and we only want a running bike, nothing special, I am wondering if it is possible to run the bike with Thundermax ECM and without the O2-Sensors.
With Power Vision it is possible to switch O2-Sensors on/off and change beetween open/closed loop.
Since I am new to Thundermax is this also possible with it?
Would safe me a lot of time while otherwise I have to weld bungs to the exhaust.
Best regards
Volker
Old 11-24-2022, 09:47 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,300 Likes on 3,656 Posts
Early Gen 1 and 2 systems the o2 sensor was optional. Gen 3 it's built in. I don't see any settings to disable the sensor on a Gen 3. You could send email to Tmax and ask.
Going without the sensor pretty much dictates that you'll need to tune on a dyno as tolerances on feuling are not that great. I'd weld the bungs on. Even if there is a map of your exact build, it could be off some.
Old 11-24-2022, 09:55 AM
sepperl's Avatar
sepperl
sepperl is offline
Thanks for sharing that info. I sent mail to Tmax. Waiting for replay.
Old 11-25-2022, 01:20 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
i woud weld in the bungs and work with it from there.
m
The following 2 users liked this post by marcodarq:
Max Headflow (11-25-2022), sepperl (11-25-2022)
AKL1
Exhaust System Topics
15
08-25-2023 01:44 PM
Dirtloco
01-03-2023 11:30 AM
AKL1
01-19-2020 03:03 PM
eddiemac
09-12-2009 06:26 PM
WIZARD
03-18-2009 03:19 PM
Quick Reply: Thundermax ECM without O2-Sensors
