Gdetting back into tuners
I got 2007. When I bought I bought a SERT, a map from a dealer, and did some tweaking for stage I. Now looking to do minor build, low compression, cams, and port. I am considering dynojet power vision 4. Price is part of it and looks simple.
I am not sure I will get it on dyno, and not like to squeeze after hp out of it. Just freshing up the engine, and would like to see if I can cool it down a bit by removing EPA restrictions.
I have not kept up with this technology, From my reading it looks like it flashes the ECM, and is not a piggy back device?
If you did want live data, then you would plug in, and go for ride. But you do not need to leave plugged in? Is there any advantage to leaving it if not trouble shooting?
Can it be tuned, or is just load maps in?
I created an account hoping to see what maps they have, but the app doesn't seem to do anything if, not connected. I was hoping to review it.
Thanks for the help.
M Oclaf (12-20-2023)
If you dont plan to put it on the dyno, and just wanna cool it down a bit without squeezing the horsey’s out of it i would at least suggest buying from somewhere like fuel moto that has map support. If you are not familiar with the things that gunner60 mentions then their support will be pivotal in your success with the device.
I am not familiar with the PV4 but im sure its data logging and troubleshooting capabilities are similar to the 1-2b models so its unlikely it will need to be connected unless you are actively using it to tune or log. You are correct it is not a piggy back tuner.
I am open to correction on all points.
The Powervision is a good option. It is a flash tuner meaning that it will re-write the tables in the ECM. After flashing you can remove the head unit if you like. I keep mine attached and monitor certain data parameters. There are plenty of instructional videos. Over the years I have had just too many issues with the Thundermax product. I assume it it a typo that you want to lower compression. I actually had the original SE Super Tuner Pro on mine and used my map as the starting point for playing with the PV.
I stand by post. This is a train wreck waiting to happen.
The following 4 users liked this post by 60Gunner:
My plan was whatever tuner I got to get a canned map. I was debating on auto tuning, and not sure if I was going to dyno it.
One of my carb builds I dynoed, one I did not.
My first goal is to freshen up a higher mileage bike. lifters, pads, and rings. I am not looking to spend a ton of money. This is a 17 year old bike, and I got two more, so I am not looking to max out the power and dump a lot of money into it. But since it is open I am looking at tuner, cams, and heads. I do have a SERT, and considered just getting a older computer to run it, I might even have one.
My question was do these program ECM or piggy back. When I was into this only Harley programed everything else piggybacked. At that time thundermax was way expensive, I didn't even look at their products this time. To me it looks like these newer ones flash.
I did speak to fuel moto, they said PV-1b had less issues and call backs, then PV-4, and better on my year. It is an upsell. I am not sure if I care about auto tuning. But I'll probably get it.
Problem with Fuel Moto is they want to sell kits. Myself, I'd just bore my cylinders and save a few bucks. I was hoping to buy the rest from them. But talking to them I think it will be piecemeal.
I am not sure what I am going to do for lifters. Not sure they are worth $300. Last build I did S&S. Harley ones are cheap and have lasted.
They recommended TW222, which they said was good for 96-107. I'll probably go with that. I was thinking about andrews 21 or 26, which they sell.
So whats the differenfe going to fuel moto for a tuner and just buying it from dynajet? They also have maps. I downloaded app. I wanted to look to see what they had avalable, but it needs to connect. Maybe I can find out on their site?
I'll probabloy go with fuel moto, couple bucks cheaper.
Buying a second tuner is expensive, but I'll probably do it. I can buy another licesnse for my other bike, so that is a plus. But at the moment I am pretty happy with that. By the time I do a build on that, they will say it doesn't work with current phone/computer too.
to install all of the PDF files (need acrobat reader)
http://www.mastertune.net/downloads_...re_updater.php
hth,
T.
luckiestiff (12-26-2023)
