For you guys debating SERT vs PCIII
RE: For you guys debating SERT vs PCIII
To each his own. I have a PCIII and my bike runs great with it. IF I have to pass an emissions test, I can just unhook it and run the Stage one DL the bike has. It can be adjusted and timed using the PCIII without a dyno by the user.The price is also lower (mine was about 270 bucks, shipped with appropriate map installed.
I am NOT saying a sert isn't a good alternative if you want it, just that the bad PCIII experience is NOT typical and many, many HD riders have used it for several years with great results. I also think the maps available for specific intake/exhaust combos, not available for serts without having it tuned on a dyno, at least not on HD's disc (which they have stopped including in the purchase now I've heard) make the PCIII more accurate for many people who are trying not to spend seven hundred bucks to get running right between the dongle and the tuner.
JMHO
EZ
ORIGINAL: DRAGOSBIKEWORKS
Hello guys,
Now I use PC3 on just about all my customers bikes. I use them on bikes making 75/100/245/500 horse power and never have any probs.... Now the bikes range from Harleys to metric sportbikes. The pc 3 is very easy to use and has great support. At least you can call powercommander and ask a question good luck with the HD dealers that most of them dont know how to tune them. And most people that tune serts will turn off the closed loop side so they can lower the a/f.... (Now you are talking out of the side of your neck....... That is an MMG tuning style, NOT an HD/TTS style tune..... The SERT Tuners that KNOW what they are doing with the Closed Loop set the DAFR to 13 so as to guarantee the VE's are dialed in where they need to be..., Then the DAFR is reset back to baseline... ) Now you run in open loop just like a pc3.
I hope this helps
FRANK FROM D.B.W
Hello guys,
I hope this helps
FRANK FROM D.B.W
LOL, looks like an official "SERT" campaign to me. Fact is, they are both good units, either will satisfy most non racing or uber high performance users AND the PCIII is cheaper.
I might not feel the same if I had an 07 or 08, depending on the viability of keeping or finding some advantage in the narrow, closed loop system with the SERT. Since my 06 runs great with the PCIII and it was relatively inexpensive, I really like it. I liked my DFO on my 04 WG too and it is definitely a very economical choice for just a stage one'd , pre 07 bike IMHO. Simple, user friendly and it works. It seems to me that the sert being a dongle rather than an actual "component" it is way overpriced as, in effect, simply a gateway to access thebox. IF, in fact, they have stopped including the maps on the CD, it is further evidence of HD simply milking an opportunity to charge for fixing the bike's shortcomings.
Again, maybe I am way off base but too much overcharging for simple things has jaded many of us towards MOCO "solutions" to problems native to the bikes.
JMHO
EZ
JMHO
EZ
ORIGINAL: EZ2Rider
I also thought that maps were now available online from HD and could be dowloaded to your pc as you required them with no extra charge.
Am I right here?
Hello guys,
Now I use PC3 on just about all my customers bikes. I use them on bikes making 75/100/245/500 horse power and never have any probs.... Now the bikes range from Harleys to metric sportbikes. The pc 3 is very easy to use and has great support. At least you can call powercommander and ask a question good luck with the HD dealers that most of them dont know how to tune them. And most people that tune serts will turn off the closed loop side so they can lower the a/f.... Now you run in open loop just like a pc3.
I hope this helps
FRANK FROM D.B.W
Hello guys,
I hope this helps
FRANK FROM D.B.W
What PCIII compatable bike has 500 HP????
Smells Like BS
ORIGINAL: BCguy
Maybe I'm confused but my understanding is that the old SERT or the new SE Pro EFI Super Tuner is a software package that allows you to reprogram the stock ECM by uploading a canned map (from HD or other sources) or a custom map (during a dyno tune, for example) as well as a multitude of monitoring functions. The 'dongle' is merely an interface between the ECM and your pc. You'r not paying for the dongle but the software.
Am I right here?
Am I right here?
AW
If the PCIII works for you then fine, I have no problem with that. You are guessing which increment works best on the PCIII whereas the SERT has the actual A/F mixture there for you to play with. There are 100 more settings on the SERT than the PCIII. Someone asked about downloading maps from HD, now I am not sure about that, but if you can I would love to know the link.
Somebody keeps saying that the sert is 700 bucks? No way, I paid 380 for mine off ebay from a HD dealer and 30 for the cables. Shipping and all I had about 420 in it and it was money well spent.
So tell me when you run in closed loop mode you can dial the a/f at 13.81 or lower with a sert I dont think so........ You can not with the stock narrow band 02 . So what do you do you turn it off. I try to talk in simple terms so people understand. So tell me what do you do...... I have used many of serts and tuned them. Even when I put super chargers on harleys how do you tune a sert to get lower then 14.1 in simple terms you turn it off.CLOSED LOOP............. Thats why I talk out the other side of my neck....
Frank From D.B.W
Frank From D.B.W
