Turn Signal problem. please help
Old 02-20-2006, 11:49 PM
rocamotacoca's Avatar
rocamotacoca
rocamotacoca is offline
Default Turn Signal problem. please help
To anyone that can help:
I relocated my rear turn signals on my 06 Dyna Lowrider to install saddlebags. The relocation was done without a problem but while plugging back the the wires, I blew a fuse. All my lights went out. I replaced the fuse and all my lights are working again but my left rear turn signal light won't blink. It blinks when I activate the factory alarm but not when pushing the left turn signal. My front left turn signal light blinks as well as both of right side front and rear signals lights.
Any help?
Old 02-21-2006, 01:43 AM
kruzin's Avatar
kruzin
kruzin is offline
Default RE: Turn Signal problem. please help
You may want to be sure you are plugged into the right socket. When I did the relocation on mine that is exactly what I did, plugged it back in the wrong connector. The other thing is mabe you pushed a pin out or bent it over when plugging the connector back in.
Old 02-21-2006, 09:22 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Also, check the bulb and the connection in the bulb socket. If the right turn signal is working, move that bulb over to the left and see what happens.
txphatboy
Electrical/Lighting/Alarm
12-29-2016 01:51 AM
wanabe
08-16-2010 10:30 AM
Iamopie2FLHRC
12-19-2008 11:28 AM
guild
General Topics/Tech Tips
05-22-2007 03:07 PM
rocamotacoca
02-21-2006 12:18 AM
Quick Reply: Turn Signal problem. please help
