turn signal problem
Old May 12, 2007 | 04:42 PM
guild's Avatar
guild
Default turn signal problem
i have the stock four turn signals lights with the front lights being on all the time...when i hit the left turn signal button everthing works fine if i hit the right button the front turn signal
bulb gets real bright and the rear does not flash at all.. Any ideas... Thanks, wayne
Old May 13, 2007 | 02:54 AM
bobcowan's Avatar
bobcowan
Default RE: turn signal problem
First, pull the bulbs and check the sockets. Make sure they are clean and free of corrosion. Next, check your grounds, make sure they are clean and corrosion free. Finally, replace the turn signal module.
Old May 13, 2007 | 10:53 AM
guild's Avatar
guild
I found the problem someone did some poor wireing and when i lowered the bike the wire rubbed on the rear tire and split the wire...
Old May 22, 2007 | 03:07 PM
ride99fxd's Avatar
ride99fxd
Sounds like the rear bulb is burned out. Remove it and look to see if the filament is broken. If you can't tell, swap with the left bulb and see if the problem follows the bulb.
gilyoyo
Nov 1, 2010 03:07 AM
wanabe
Aug 16, 2010 10:30 AM
holt2010
Aug 8, 2010 09:20 PM
touron2
May 26, 2010 06:07 PM
rocamotacoca
Feb 21, 2006 09:22 AM
