EG starts then dies
EG starts then dies
I have an '02 Electra Glide. This afternoon after doing some front brake work, took itfor a ride and ran great. Set in the brake pads and then came home. AfterI got home decided to put on the new K&N air filter. After I got the A/F on, went to start it up and it started then died. Tried again and it would start and rev for 1 twist of the throttle and then die. Acts like it is not getting fuel. Pulled the a/c off thinking I might have knocked off a wire or something to the fuel injection but all looks good. Tried pulling out the diagnostic trouble codes but don't know if I am going about it the right way. I hold the odometer reset button down then turn on the ignition. I get a display of "d01CLr" as I push the reset button it scrolls through "d02CLr" all the way to "d10CLr" till it shows PPU then 82883 then starts over. Anybody got any thoughts???
Thanks,
Whitey
Thanks,
Whitey
WOS Bishop
26
07-22-2012 07:34 PM
