07 Deluxe just quits
07 Deluxe occasionally about once a month will be just going down the rode and shuts off. Power stays on lights don't blink and it just quits. Turn ignition switch off and on and it fires right up. If you turn the kill switch off and on it won't fire unless the ignition switch is turned off and on. All hardware has been checked from wiring to connections. I guess its time to start changing parts. Any ideas?
Thanks
Thanks
HD techs well trained?
Best of luck with that. Harley claims no knowledge of any problems YET, keep reading these forums or others on the Net and there are plenty of HD's doing exactly the same thing...as does my '05 Deluxe.....mine was in the shop 3 times and all they could do was tell me they could not replicate the problem...oh and the best was, I mentioned that I saw someone online who said they had a prob with their ignition switch.....are ya sitting down, on my work ticket the dealer actually put "checked Ignition Switch at owners request" Uh, HELLO, my bike shuts down when I'm riding, don't ya think you would want to check that without me having to ask ya to? Geez. I am giving this bike 1 more shot, if the problem arises again, I will take it to the next closest dealer to see what they can do, if they pull the smae story as the previous dealer, it's going to be bye-bye HD for me. I need a bike I KNOW will get me where I want to go.
Thanks
Thanks
Mine did the same same as you descibed and I let HD know about it.Dealer and C/S.Yet either did nothing.NHTSA form filed along with other issues I had at the time.First check all your grds,ECM plug for moisture or pushed pins.Mine would never throw a code and would do it whenever it wanted,sometimes next day,sometimes 100s of miles later.Replaced the crank sensor and problem never came back.
I have a problem that occurs (twice in 3 months), which seems to be fuel related, like maybe the pressure regulator or pump. The bike just starts running like crap, then clears out and runs fine. The caveat though, all the time in any gear, laying on the throttle causes the bike to skip and fart, starving for gas it seems, then takes off. going in to HD in a couple of weeks. But never does the bike just shut off. Just hard to stay idling until it clears out..
