When did HD make the switch from 8 degree injectors too 25 degree?
RE: When did HD make the switch from 8 degree injectors too 25 degree?
Now i know that it is a service bulletin. But i am curious as to if harley started putting 25s on new bikes. Also how would one tell if they have 8 degree injectors? would it be by build date or do you need to take a look at the actual injector?
You all need to utilize the search function....
This is a dead horse.....
The 25's have been the norm on the 06 CVO's...
The 8's are too small for the new 46mm Induction module....
Not all bikes are bearing the brunt... Mostly Touring bikes.....
25's are the norm on all bikes since mid Feb....
No RECALL....
You can tell by the part # on your injector....
No RECALL....
Thanks Bob,
My Ultra is an '03, but I have the 103 upgrade.
I don't feel any prob's in the seat, So, I should be OK??
I just get to thinking about it every time it comes up.
thanks again for "ALL" your informative posts.
Inquiring minds what to know! lol
chappy
chappy
ORIGINAL: socalsoftail
Was there a recall on the 8 degree or just a service buelltin? Hope this isn't a dumb question I look up the info in the various forums but didn't get that info out of it.
I have an interesting and puzzleing situation. I had the 25 degree injectors changed out, not so much that I wanted it as the dealer felt I needed it I had one incident with a bad stumble, and near rear ended leaving a stop light, so when the bike went in for the 5K sevice, they changed them out. Here's the twist, since then the motor idles rougher, it smells rich at idle, doesn't pull without initial hesitation when feeding full throttle at moderate speed and about 3K rpm. But here's the real puzzle, it also has the 6200 rpm redline....I didn't think this was in the recalibration with the changeout of the injectors? It's been awhile since the changeout, but I'm taking it back in to have the dealer varify exactly what calibration was done, I'm betting it was the stage one. My bike is bone stock, and I'm even willing to pay out of pocket for them to check it, I'm confident it's not right.
Thanks,
Mark
Thanks,
Mark
