Throttle cable install w/o lifting tank?
Old 04-27-2009, 10:51 PM
Kbore's Avatar
Kbore
Kbore is offline
Default Throttle cable install w/o lifting tank?
You guys ever install throttle cables on a Tc-88 throttle body without lifting the tank? Seems like you could pull a "fish" through when removing the old cable (one at a time) , and pull it back through with the new cable attached. What do you think?
KB
Old 04-27-2009, 11:41 PM
Zacharia_11's Avatar
Zacharia_11
Zacharia_11 is offline
I think it would be a lot less work to remove the tank. I hesitated to remove mine, but its pretty straight forward if you have a manual. Tank drain was my biggest hurdle, i should have researched it more on the forum before i did it. Ended up with about a half gallon of gas on the garage floor. doh
Old 04-28-2009, 07:56 AM
Kbore's Avatar
Kbore
Kbore is offline
I've pictured the gas spilling all over the floor thing. My crossover is crimped on...
Old 04-28-2009, 08:14 AM
Zacharia_11
Ya, mine had a black crimped clip on it too. A flat head screwdriver removed it. I just replaced it with a 0.99 clamp from lowes. The easy way is to get a couple vice grips and clamp down either side of the cross over, then cut the middle. Release one side into a tube to drain, then do the other. You just need to replace the cheap rubber tube and the 2 clamps.
You could probably get away with your fishing, feeding idea and not remove the crossover. Take off all the bolts and slide one of those mini plastic bottles of coke inbetween the frame and tank along the 'backbone' of the bike (Drink the coke first..). That might give you some room. I'd just be ready for plan 'B'.
Old 04-28-2009, 10:06 AM
iclick's Avatar
iclick
iclick is offline
KB
I've never replaced the throttle cables on any of my bikes, but I would think they may be clamped somewhere under the tank. If so removing the tank would be needed.
Go to Harbor Freight tools and buy a pair of plastic crimping pliars, which you can use to crimp the rubber crossover hose. Once you do that you can pull the hose off one side and immediately plug it. Obviously, have a suitable plug handy. In the past I've used one from a vacuum-hose-plug kit purchased from Auto Zone, and I think the ID is 1/4".
If you have EFI you'll also need to purge the fuel pump and that procedure is outlined in the service manual.
Old 04-28-2009, 10:32 AM
Zacharia_11
Mine wasn't clamped it was seated in a sort of a half circle plastic holder along with the electical wires. I can see it if I raise the tank on my bike and use a flash light. I ended up having to reconnect my Fuel gauge indicator in this manner on the other side.
That said, I sill beleive it will be easier just to remove the tank
Old 04-28-2009, 12:48 PM
Kbore's Avatar
Kbore
Kbore is offline
Thanks for the replies. I should have learned my lesson when trying to not take off the exhasut to remove the clutch cable cover (Road King). I spent at least 3 extra hours trying to figure out a way to not take the whole exhaust down. In that time I could have done the whole job ( I took the whole exhaust down). I'll purge the Fuel Pump and remove the tank. Dont want to be saying "Plan B" should have been "Plan A". Thanks!
Old 04-28-2009, 01:08 PM
Zacharia_11
Funny you say that. The morning I was going to do my clutch cable I drove around for 3+ hours looking for an offset tool that would let me torque the cover screws so I wouldn't have to take the exhaust off. Final said screw it, I am wasting time and effort on 'the easy way' and probably could have been done with it. Good luck on the project.
Old 04-29-2009, 08:33 AM
Squiggs's Avatar
Squiggs
Squiggs is offline
I recently replaced my cables. I was able to do it by just raising the tank and moving it back as far as the crossover would allow it. In fact, I had to do it twice...
Old 04-29-2009, 09:36 PM
ubreal's Avatar
ubreal
ubreal is offline
Take off the tank after you do you will be glad you did. It is not that hard to do I just did mine two weeks ago if you want to do a good job get some clear heat shrink tubing from e-bay and slip it over the part of the cable that’s under the light and the tank where nobody can see. this will give you more insulation between the braded cable and your metal. On mine I did it double the shrink tubing is very cheap you just have to wait for it to arrive at your house. Buy a cheap heat gun at Lowes for 20 bucks. Trust me I did it on all my cables accept my clutch cable after seeing my friends bike I am glad I did it. But that’s another story.
Quick Reply: Throttle cable install w/o lifting tank?
