Need PCIII temp fix........help
I just picked up a PCIII. I have an 06 Street Glide and Wild Pig slipons. I haven't installed a free flow air filter yet and wanted to install the PCIII and pipes with the stock air cleaner just for a week or so. The canned maps that they have are for totally stock or Wild Pigs and SE A/C. How can I read or alter the map to work for me temporarily? What will I have to change to the stock map if I just install the Wild Pigs? Can I just lean or richen the entire map?
RE: Need PCIII temp fix........help
Try one of the canned maps for Wild Pigs with the SE aircleaner. In my experience, Dynojet maps tend to run a little rich anyway, so it probably won't hurt anything. If you're only running this combo for a week or so, it's probably not worth fiddling with much beyond that.
Uncle Peepers
Uncle Peepers
chapdaddy
06-09-2007 11:37 PM
