2001 Road King Classic - How do I pull codes?
Old 07-13-2009, 01:16 PM
w00dlands's Avatar
w00dlands
w00dlands is offline
1st Gear
Default 2001 Road King Classic - How do I pull codes?
I just bought a 2001 Road King Classic. I've only ridden it a few times, but after it's warmed up, the engine runs very rough when slowing down, and when at Idle. At times, I can also smell a heavy fuel odor, like the bike is running too rich
I've heard the engine temp sensor is a semi common problem with these... I honestly probably WON'T do the repairs myself, but since I'm in the automotive repair business, I want to see if I can pull the codes myself...
There has to be a way to see what codes are in the ECM... right?
Old 07-13-2009, 01:21 PM
Scout's Avatar
Scout
Scout is offline
Old 07-13-2009, 01:27 PM
w00dlands's Avatar
w00dlands
1st Gear
Thanks! I'll try that and see what kind of trouble I get myself into!
Old 07-13-2009, 01:37 PM
Scout's Avatar
Scout
Scout is offline
You'll not get in trouble
Honestly, it's easy. I just hope there are no suprises.
Handro (03-09-2024)
Old 07-13-2009, 01:46 PM
w00dlands's Avatar
w00dlands
1st Gear
Hmmm... well, took the right side saddle bag off, and couldn't find a data connector... back to the drawing board
Old 07-13-2009, 02:26 PM
Scout's Avatar
Scout
Scout is offline
Thers's no engine light coming on now? The code is only to tell you what code is reporting a problem, not what is wrong. Is there a power commander or a SERT installed?
Joe
Old 07-13-2009, 02:32 PM
w00dlands's Avatar
w00dlands
1st Gear
No enigne light on, was hoping/thinking that even though there's no MIL on, there may still be info in the computer. I know on cars the ECM can still give you information even though there's no light on...
Old 07-13-2009, 05:26 PM
ajayrk's Avatar
ajayrk
ajayrk is offline
2001 has the Magnetti Marelli injection system not the later Delphi system.
Before you test for codes, clean the throttle body. At the top of each throat is a small hole. Those are the Idle Air Bleeds. If they get dirty the proper amount of air will not be metered at idle. Put the straw of the brake cleaner or carb cleaner into the holes and clean them good as well as the entire throat and throttle plate. Protect the motor finish with rags. The idle is controlled by a stepper motor that cracks the throttle for start up. Once warm the motor backs off and the hot idle stop screw controls the idle speed and air passes through those holes to maintain idle.
Codes are retrieved by turning the ignition switch on for three seconds and then off. Do this twice. Then turn the switch on for eight seconds and the check engine light will flash a number of times and you have to count the flashes and look up that number in a code chart. Now you are really confused.
By the service manual.
By the way the head temp switch is located at the rear of the front head on the left side. Pull the boot back, use a 3/4" socket and remove and replace.
Delphi vs M/M: http://www.hdtalking.com/diagnostics...delphi_fi.html
Old 07-14-2009, 07:16 AM
w00dlands's Avatar
w00dlands
1st Gear
Thanks AJ! I'll try that when I get home tonight (too hot to ride to work today!!!)
Kwadman
General Topics/Tech Tips
07-11-2018 07:18 PM
Pender1
Motorcycles For Sale
03-26-2014 09:37 AM
txfxstrider
EVO
13
09-16-2008 06:38 PM
mikejunior7
04-22-2008 11:16 AM
badas roadking
08-02-2006 08:08 PM
Quick Reply: 2001 Road King Classic - How do I pull codes?
