Brake Light/ Relay Issue
Old May 3, 2010 | 08:52 PM
raafter's Avatar
raafter
Default Brake Light/ Relay Issue
Hey Fellas
I've got a '10 FLHX with a brake light issue. It seems as though my brake is always on "Braking" brightness. When I pull the brake relay the brake light goes to a regular "driving" brightness. When I apply either front or rear brake nothing happens because the brake is bright as if the brake is already applied.
I've checked the brake light fuse, the accessory fuse & they look fine too me.
I'd installed an amp & wired my GPS directly into the CLA inside the fairing.
I decided not to overload the CLA so wired the in fairing power antenna to another power source.
In an effort to trouble shoot if the whole CLA thing was an issue I undid the stereo/gps/powered antenna & switched the brake & accessories fuses as a "just in case" all scenarios resulted in the same thing... a brake light that looks constantly "engaged" (bright like when applying the brakes) & nothing when actually applying the brakes.
Any thoughts or suggestions?
Old Mar 16, 2022 | 05:41 PM
egaynor's Avatar
egaynor
Stage II
Seems they are normally closed brake switches. I am having the same issue though, did you resolve your issue?
sorensentyler
Aug 4, 2014 08:24 PM
rsnky62
May 2, 2010 10:44 PM
moblmowr
Feb 29, 2008 08:00 PM
Jonny Cannon
Jul 11, 2007 09:19 AM
Skip
Aug 12, 2006 01:48 PM
