What's the best option for fuel management
However, he made this one thing very clear...
Running just a set of SuperTrapp SE slipons is fine without doing anything else to the bike. However, DO NOT put a breather kit on it without doing the SEST or some other form of fuel management because the bike will run WAY too lean.
For now, I like the way the bike runs and sounds (minus the decel popping), I might just run it like this and leave it.
Anyone else out there that has done this? Pros? Cons?
Until you decide I would suggest putting the stock filter back on to prevent any damage from the TOO LEAN condition. This will keep the sound you like and may lessen the decel popping
Hope this helps and doesn't confuse.
http://www.mastertune.net/index.html
Last edited by OIF08Streetglide; 09-13-2010 at 07:23 PM. Reason: added link to web site.
Hey Thanks Gents....
Just to be clear. I didn't put the breather kit on. I'm just running the SuperTrapps right now. I was in there to purchase the breather kit when we were talking. That's when he explained to not put it on without doing the SEST or some fuel management first.
I was looking at the Fuel Pak as well as the TTS and a couple others. The Ridemaxx looked cool too but I understand they're not in biz anymore. The guys at Fuel Moto seemed very cool too but I've had some reservations about the PCIII.
inaroush, did you notice any major difference in fuel economy with the Fuel Pak?
...However, he made this one thing very clear...
It would be accurate to say that 14.1 is leaner then 14.0 but too lean? I guess that depends on one's position with respect to what is TOO lean.
This is a great example of why it's important to learn the HD EFI system yourself...just TOO much misinformation out there.
Good luck
When I got my S&S gears/cams (510g) and Daytona Twin Tec fuel mgr (my indy recommended) about 10k miles ago, I only had Stage 1 too. I really noticed a great improvement in torque and throttle response. Since both were added at the same time, I'm not sure if my gains were the gears/cams, Daytona Twin Tec or both. They're simple plug in and around $200.00 on ebay. Here's a link of the one that I have on my 02 RKC. 43K miles now. http://cgi.ebay.com/ebaymotors/Harle...Q5fAccessories
