Completely Disabling Buttonless Fob Security Systems ('07 up)
Old 06-30-2012, 04:36 PM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Then you probably installed the the Makuni flat slide carb and dyno tuned my old Superglide in late 2002. It was a hell of a job, that bike ran great and carried me all the way the Alaskan Hwy, the Dalton Hwy and then down into old Mexico. Thank you for your attention to detail sir!
Old 05-12-2013, 07:19 PM
Daddy bojam's Avatar
Daddy bojam
Daddy bojam is offline
Stage I
Smile 2010 FXDWG worked great
I did this on my 2010 WideGlide & it worked great. The part numbers were different of course. I followed the steps and it took 30 min like you said. My TSSM took a dump on me so I decided to get rid of the whole system. I have been rideing Harley's since 1986 and have only had a master lock & really good insurence, neither of them ever took a dump on me. Thanks a lot man!
Old 06-22-2013, 11:23 AM
jdsthatcher's Avatar
jdsthatcher
jdsthatcher is offline
Stage I
Default not working :(
i installed the new tsm, ignition switch to on, turn on ignitions switch, but not start. the security light comes on but never turns off (at least for my 22 min wait) in order to do initial starting of engine??
Old 11-11-2013, 07:11 AM
Campy Roadie
Great write up. I have my security system disabled but it still searches for the fob when proximity devices come into range. I didn't want Security but it came with ABS. The corresponding battery drain, especially when it's parked in the parking garage, cuts into battery life.
Old 01-02-2014, 08:23 PM
nhhdrider's Avatar
nhhdrider
nhhdrider is offline
Alarm system should not create a excessive parasitic load to drain battery. Unless you are storing it in the garage for long periods of time which then you should have a battery tender or disconnect the battery. Which just means you need to ride more!
Thought: Velcro the fob to the underside of the seat. Now you never have to carry it with you and still anyone can start and ride the bike away as with no security system.
Old 01-02-2014, 08:53 PM
Campy Roadie
Actually, everytime someone walks by with a proximity key fob the system "comes to attention" to see if it's the owner. In a parking garage environment this happens hundreds of times a day.
Ever notice the coralation between the HD proximity system and the fact that not many people with it get more than 3 years out of a battery? As compared to 5 years for those that don't. Don't kid yourself, a motorcycle electrical system isn't as robust as a car system. Everything is on a smaller scale but the draw for proximity systems is about the same. In the end, something is gonna give; battery life.
The following 3 users liked this post by Campy Roadie:
Dr.Lou (08-09-2020), Rog1015 (07-11-2019), tar_snake (10-28-2018)
Old 01-03-2014, 09:35 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
If you store the fob on the bike it will drain your fob battery faster, then the bike won't start at all until you replace the battery.
Old 04-24-2014, 09:55 PM
Justice.Designs's Avatar
Justice.Designs
Justice.Designs is offline
Stage IV
Originally Posted by Nexus9
For those of you do-it-yourselfers out there (like me) who don't want to have to make the trip to the dealer every time they want something done, let me relate my experience with removing the TSSM non-pushbutton security system on my '08 Ultra. This may work for other bikes, but I'm not a factory mechanic - so I can only confirm that this will work on '07 and later touring. One of the advantages of doing this yourself is that you can keep your original module (along with a printout of this post) and re-install it at any time without another trip to the dealer, or if the bike's new owner wants a security system.
The factory security system is contained within the Turn Signal Module (TSM), which becomes a Turn Signal Security Module (TSSM) when it is so equipped. If you are disabling the TSSM (do NOT want a security system on your bike) then you have a TSSM installed now, HD p/n 68924-07. This is a roughly cone-shaped device in a black plastic case, mounted vertically under the seat and to the right (starboard) side. Mine was held down with a silver metal clip. The first thing we need to do is replace this item with a NON-security equipped TSM.
So before you go hunting for the TSSM on your bike and removing it, buy the part you're going to replace it with - in this case, HD p/n 68920-07. They are $114 new from Harley, but I found many on eBay and bought one for $24.95 including shipping to my door. You will also need (highly recommended) a 2 amp (or so) motorcycle battery charger to complete the job safely.
Okay - now, we have everything we need to do the job completely. Find the TSSM under the seat of your bike, remove the clip, and lift it out. There will be TWO connectors plugged in to it; remove both. Note that one of the plugs is larger than the other - this is the input, ECM, and turn signal connector - we will use this again. The smaller plug is the output for pager and siren - tape that one up to protect it and set it aside for now. Plug the larger plug into your new TSM, and slide the assembly back into place, carefully storing the loose connector where it won't rattle or take too much wear.
Whoa. That's it?
Nope. If you try to start your bike at this point, it will rumble and die, and you'll be cursing me for life. The bike knows that the security system has been compromised, and is trying to protect you, the owner. Getting it to feel all warm and fuzzy about its new body parts takes another half an hour - which kind of discourages the swap-out-and-quick-getaway-routine by a more unscrupulous rider who just happens to be enamored with your new paint job.
In the next step, we're going to have the bike's ignition (and lighting) on for more than half an hour, so here's the part where we plug in a 2 amp battery charger to keep things live. With the battery charger hooked up, perform the following:
1. Be sure the ignition has been OFF for 15 seconds or more before starting the procedure.
2. Set Run/Off switch to RUN.
3. Turn ignition key on, do not start. Verify that the Check Engine Light and Security Light come on, and wait for them to go out.
4. Attempt a normal start with the Start button. Engine should come to life and then die. The Check Engine Light should light up and stay on.
5. Wait ten seconds. The Security Light now comes on. The ECM has now entered communication mode with the TSM for the next ten minutes. Look at your watch and do something else for the next ten minutes, but don't shut off the bike, let the battery die, flip any switches, or unplug anything electrical. Just polish the fenders or something.
6. In ten minutes, the security light will turn off. Within 15 seconds, turn the ignition key Off and back On. This Off-On motion should be crisp, completed in two seconds or less. The Security Light comes back on, and you have another ten minute wait.
7. When the Security light goes out again, repeat step six.
8. When the Security Light goes out this time, do the Off-On thing, then when the Security Light comes back on again, shut the ignition OFF. Wait at least 15 seconds, during which time you should be (carefully) unplugging your battery charger (unplug from the wall outlet, then from the bike, right...?).
9. With 15 seconds or more gone by, turn your ignition on, confirm the Run button, confirm neutral, and start your bike. You've created a happy marriage between your ECM and the new TSM, and you no longer have to worry about having a key fob or memorizing a security code. Now you can just worry about someone riding off with your bike whilst you're suckin down a brew in the local pub - use the fork lock!
If you're like me, you'll never remember all this two years from now when you're selling your bike, so print this out, take the battery out of your key fob, and put the fob, TSSM, and this paper in a ziplock bag and store it wherever you would go to look for it two years from now. Happy riding!
Just so everyone knows, I just did this mod on my 2007 FXDSE Screamin' Eagle Dyna, and it worked perfectly. Down to the second with the security light going off, and flipping the key off/on... I had my doubts whether I would pull it off, but it totally worked, and I went for a ride (with no FOB) and shut her down, and she started right up. I'm stoked!! Thanks for the great info and right up... from several years ago!
Old 07-11-2014, 08:16 AM
Nexus9's Avatar
Nexus9
Nexus9 is offline
Glad it worked, glad I could help.
Old 07-11-2014, 08:58 AM
gusotto's Avatar
gusotto
gusotto is offline
Originally Posted by IBGary
My fibs seem to die at the most inopportune (asked the wife to spell that) times. I had to learn my code and how to enter it. Once I learned how it was really simple.
I replace my FOB battery every year (they're cheap) and carry extras on the bike. I usually replace the old battery with one of the spares (after checking battery voltage) and then I know my spares have the most power.
I could go longer than every year but it's just part of getting the bike ready in the spring.
Personally, I don't see any reason to disable the security system. I know my bike won't start and I added the loud Harley alarm to the bike. I can travel and know if anyone is messing with the bike.
Robert Wyatt (02-05-2020)
Quick Reply: Completely Disabling Buttonless Fob Security Systems ('07 up)
