Cylinder misfire at idle
Old 05-25-2011, 09:59 PM
foggiehat's Avatar
foggiehat
foggiehat is offline
Stage I
Default Cylinder misfire at idle
I own a 2005 Detroit Chopper Aggressor softail w/a 96 C.I. S&S motor. My problem is when at idle only one cylinder fires. I changed the plugs and it worked for about 15 days and samo samo. What could be the possible causes?
Old 09-16-2012, 08:51 PM
tati's Avatar
tati
tati is offline
Stage I
fuel pak problem????????????.
Old 09-17-2012, 05:04 AM
maddghost's Avatar
maddghost
maddghost is offline
maybe the parade mode (eitms) is kicking in too early?
Old 09-17-2012, 08:10 AM
ajayrk's Avatar
ajayrk
ajayrk is offline
Is it an EVO type engine with the ignition in the nose cone? If so the ignition module may be failing because it is in a very hot environment.
Old 09-17-2012, 09:18 AM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
Change those plug wires.
Sounds like a small fracture / break and at low speed the pulse is slow enough to not make it past the break / fracture in the wire.
When you swapped out the plugs you repositioned the break and it made contact for a while.
I don't believe any EVO had the "one cylinder stops firing" feature like when the new bikes overheat at stops.
And most EVOs ignition module is on the frame (all factory systems are). Only aftermarket units were designed to mount in the nosecone, and some of them fail due to the high heat in that area.
Old 09-17-2012, 12:33 PM
springers4ever's Avatar
springers4ever
springers4ever is offline
try a different set of plug wires ....from a buddies bike ....bad wire will run you crazzzzy !!
grasmo
11-18-2015 07:09 PM
wammerjammer
EVO
15
11-13-2012 03:39 PM
car5car
12-03-2009 10:22 PM
e666h
05-27-2008 06:18 PM
gritz1
Exhaust System Topics
07-29-2007 01:59 PM
Quick Reply: Cylinder misfire at idle
