Add on EFI module failure-anyone??
Old May 26, 2008 | 05:23 PM
e666h's Avatar
e666h
Default Add on EFI module failure-anyone??
Anyone have a add on EFI module fail? Bike seems to be running on 1 cylinder. Plugs o.k. Didn't get to check coil yet. Running
Cobra FI 2000r. Not sure how to diconnect unit + go back to stock. 07' bike. Any thoughts??
Old May 26, 2008 | 08:01 PM
im's Avatar
im
Default RE: Add on EFI module failure-anyone??
consider view of link...
link for cobra website below...
unit is suppose to be plug/play with factory style connectors..
seems like if you can locate unit..you can then follow connections and it should explain itself...
connect same w/same
http://www.cobrausa-hd.com/category....=3&bmid=12
Old May 26, 2008 | 08:19 PM
BM83's Avatar
BM83
does it seem to be idling on one cylinder or running on one cylinder when above idle? The 07s have a heat management built into the ecm that shuts down the rear cylinder at idle under certain conditions.
Old May 26, 2008 | 08:26 PM
e666h's Avatar
e666h
Both. Does it When its cold.
Old May 26, 2008 | 09:48 PM
chopperjockey's Avatar
chopperjockey
Pull the Cobra connectors off of the Injectors and check for a loose or broken wire . Early models had a problem with wires in the injector plugs coming loose or pulling outdue to being to short. Call Cobra.
Old May 27, 2008 | 06:18 PM
e666h's Avatar
e666h
Thanks Chopper. That was the problem. Wire broke off at connection. Beefed it up a little but still getting rid of it.Let me down in the middle of nowhere. Ruined 3 day weekend plans for me + 4 others. Going with SERT next week. This unit was recommended to me by closest dealer who doesn't have a dyno. I'm sure I'll get better performance+reliability with a good tune.
wammerjammer
EVO
15
Nov 13, 2012 03:39 PM
car5car
Dec 3, 2009 10:22 PM
e666h
May 26, 2008 05:15 PM
alwayswrenchingmyhog
Shovelhead
May 22, 2007 01:30 AM
SKJOLD
Ironhead
Mar 3, 2006 11:40 AM
