SERT Stage II Map for 07s 96"
I have a 07 RK Custom 96" Big Sucker and D&D's I down loaded 159PZ003 "Stage I ?" I bumped the closed loop bias, and played with the VE tables and it runs real good. This is the only 07 96" touring map. There are several 103" maps for the same bike. Assuming a cam change down the road.
Can I use a 103" map change the displacement to 96" and down load it. Seems like it would be easier to fine tune a "Stage II" than reworking the orginal map after changing cams.
