I think it needs to be re-maped
Old 01-21-2007, 05:09 PM
Williamsonmj's Avatar
Williamsonmj
Williamsonmj is offline
4th Gear
Default I think it needs to be re-maped
I have a 2007 Dyna Street Bob that i just bought 3 days ago. I went on a little ride today and it was good untilI stoped for a while and then I started it up again. the check engine light came on alot and it sputtered thru all the gears. Also when I would come to a stop it would shut off, and was hard to start again. The engine light has come on before on a previous ride. Like i said i have only had the bikeabout 3 days. I know the bike it fuel-injected so i only let it warm up for about a min or so, Do I need to let it warm up for longer? I am going to tkae it to the shop on Tuesday if it will make it. Not really the best tast for a first Harley. Any info would be appreciated.
Old 01-21-2007, 05:31 PM
johnny canuck's Avatar
johnny canuck
johnny canuck is offline
Default RE: I think it needs to be re-maped
fuel level?
That's why you have a warranty.
Sorry about your experience.
Old 01-21-2007, 05:37 PM
Williamsonmj
4th Gear
Fuel Level?
Old 01-21-2007, 11:34 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
ORIGINAL: Williamsonmj
Fuel Level?
He is asking you if you have enough gas.
A friend of mine has a dyna and we were sharing Harley stories(true ones) and he told me about how his dyna vibrated so much that it broke or disconnected a wire underneath the gas tank that went to the manifold........ran like a tird much like what you are describing. His was brand new as well.
BTW, I have a nephew named Matthew Williamson.....
Old 01-22-2007, 02:09 PM
BlkSilverado's Avatar
BlkSilverado
BlkSilverado is offline
My Ultra Classic did the same thing.. If you pull the codes and have a temp sensor problem look at the temp sensor at the rear of the front cylinder and verify it's plugged in. Mine had the harness ran on the outside of the horn bracket which made the plug pop loose. If thats it reroute the wire to the backside of the horn bracket and re-plug in the sensor. You'll also have to clear the codes. This can be done using the speedo and reset button (search the forum for info) Hopefully thats all it is, like I said mine had the same conditions.. Good Luck
Ace102uk
04-09-2017 08:59 AM
HELDVR
10-04-2010 08:10 PM
lisabos1
08-25-2007 11:46 PM
Williamsonmj
General Topics/Tech Tips
01-23-2007 10:15 AM
Williamsonmj
01-22-2007 10:51 PM
Quick Reply: I think it needs to be re-maped
