possible fuel injection problems
anyone have any advise. have a 2011 street glide 103 fuel injected. just custom painted whole bike. putting back together all wires are hooked up, gas tank has 2 gallons, fuel pump is working, have spark, all fuses are good. it cranks but wont fire. if you put small amount of starter fluid it will fire then die. aks like it is not getting fuel to injectors. did not remove all the tank inside gutts. i taped everything of really good and drained the tank and blew it out with compressed air but did not remove inside gutts of gas tank. everything on bike works like it use to (lights and misc stuff)
Did you say that you blew the tank out with compressed air? You may want to take the guts out and examine the fuel lines on the fuel pump assembly. You may have dissassembled something accidently with that compressed air or you may have damaged the flexible plastic hose or hoses in that assembly.
ziggymotion
Exhaust System Topics
09-03-2007 10:58 PM
