Looking for some help on no spark!
got a 06 Swift Punisher with 117 cu in S&S that is giving me fits. Here's what I've done so far to help. Replaced ignition (IST) S&S, engine temp sensor, checked coil wires and plugs. Replaced coil (single fire) I'm getting 12.8 volts at the center wire on the coil and it drops to around 10 volts when cranking engine. had to replace entire wiring harness as the original one died. I've double checked all the wire connections and they are correct. It's my understanding that that the crankshaft sensor tells the ignition module when to discharge the coil to fire the spark plugs. Sooooooooooo am I right to assume that the crankshaft sensor needs replaced?????
Any help would be greatly appreciated.
Ben
Ben
