Which calibration file should be used with a 103 Stage 4 Race kit?
I have a couple of technical questions concerning HD calibration files.
The 103 Stage 4 Race kit, pn 92500010, (not the street kit), is described in the Screamin' Eagle catalog as using "CNC-Ported Factory cylinder heads with high performance valve springs" and the "SE-259E" camshaft set.
The HD "calibration description" file that comes with the Supertuner software package, says that a 2014 103 cu in Softail with this kit should use one of TWO different calibration files:
358SCZ002, if it uses "CNC Stock" heads and SE-259E camshafts set
358BAP002, if it uses "110+" heads and SE-259 (note: no "E") or SE-251 cams
I have that kit installed in my 2014 Breakout, when the bike had only 68 miles on it, and the dealer loaded a file that the Supertuner software screen describes as "358BAP00201", to use during the break-in period for the kit, before doing a detailed dyno tune.
This struck me as odd today when I noticed that file name, because I would THINK that my "CNC-Ported Factory cylinder heads with high performance valve springs" would correspond to the "CNC Stock" heads, which apparently require the OTHER calibration file: 358SCZ002.
So, here are my questions:
1. Am I correct in thinking that the calibration file is a "canned tune"?
2. Why would the dealer have used "358BAP00201" instead of '358SCZ002" given the heads in my kit?
Jim G
Jim G
The answer to the second question should be posed to the guy at the dealership that loaded that map. His reasons are the only ones the matter.
I would get the bike on a dyno for the break in tune and bring it back for the final; a good tuner can seat the rings on the dyno. Some tuners will do a couple of pulls to verify that AFR is OK for break in for $50 and deduct that from their standard cost for a full tune when you are ready.
JimGnitecki
Engine Mechanical Topics
04-22-2014 12:59 PM
greglal
11-22-2010 08:39 PM
