Fuel line repair made a little easier - 2000 & earlier
New lines are installed, It took longer to get them screwed into the tank then it did to replace the clip ring and o rings at the fuel rail.
But for now it appears there are no leaks.
I took it out for a 8 or 9 mile ride and the temp sensor replacement seems to have corrected the other problem. I'll find out for sure when I can get out and go for a decent ride this weekend.
Congrats Crash. I'm pretty sure your fuel leak problems are over and I'm glad your back-in-the-wind. I am sort of a nut about having spare parts and finding the replacement O-rings for the Goodridge lines is likely not necessary. You don't hear much (if anything) about those leaking, but I would still have a couple of those small snap-rings in my tool kit anyway. The Goodridge lines do crimp the o-ring on the very end of the nut where it tightens into the check-valve (in the tank), but you're likely not going to have to remove them again unless you have to remove the tank for some reason.
I'll buy your old rubber lines and fittings and pay the postage if you don't want to keep them. I try to keep a couple of emergency sets on hand.
HIT THE ROAD!
HIT THE ROAD!
Folks....I'm getting pretty sick-n-tired of fooling with this forum. I DON'T MEAN THE MEMBERS...I mean the mechanics of this forum. I am just tired on wating-on and having to watch stupid pop-up adds of people riding down the road, dancing, trying to do my taxes and about any other thing you can think of.
Just PM me via an e-mail and I will provide all the information you need to perform my fix.
https://www.malwarebytes.org/mwb-download/
Select free download
Do not select the Free Trial when it is being installed, that will limit you to 30 days ONLY.
Just install it and let it fix your computer. You have malware if you are getting all those pop-ups.
