What type of baffle is good?
Hi all,
I own a 1980 Ironhead all stock. I have the XLR style Drags on it. I need to put in baffles for inspection but was also considering leaving then in for the increased torque at low end. I ordered a set of cheap 4" baffles. Is there any set rule for the best setup? Thanks!
Tom
LI, NY
Tom
LI, NY
only thing about the lollipop is, I'm guessing it probably won't make it through inspection for him. I'm thinking he needs some kind of legal baffle to put in his exhaust. I haven't tried them and don't know about how legal they are as a baffle, but i've heard the Krome Werx baffle is a good choice.
http://cgi.ebay.com/ebaymotors/KHROM...3A1|240%3A1318
If you choose to make your own baffle (A.K.A. washer baffle) I have a suggestion for you.
Since you will need welding done on this, I would first pick a washer (or make it) the same O.D. as the pipe I.D. and then cut the hex head off the bolt. Hacksaw a slot into the cut off end of the bolt, slip the washer into this slot. Now weld the two together. This will give you full coverage inside the pipe, and force 100% of the exhaust to exit via the smaller hole. This will dampen the noise and increase the back pressure.
On the other hand, you can buy a set of slip in baffles for about $8. Easy to insert, drill a small hole for the baffle, and you bolt it up. Done....... pg
Thanks everyone!!!
Thanks for all the responses. I do need the baffle in for inspection so the little 4" $3.99 specials will be put in. I was just wondering after all these years has someone figured out the best setup for a stock 1000cc with drags. Oh well, Again thanks for all the help!
Tom
Tom
Got the baffles in
I just received the little 4" baffles. I put them in about 1 1/2 to 2" They do quite things down and get rid of the deep sound. I can say I don't like the way they sound but I'm giving them a chance. I rode around today checking throttle response and it all seems good. I do miss the deeper sound. I'll see how long I can put up with them.
BTW, I did pass inspection!!!
Thanks for everyone's help!!!
