Rewiring a 74 Sporty
I am trying to rewire my 74 sporty but I have no idea were the brake light switch for the rear brakes go. If anyone can show me a picture it would be a great help. The location is the biggest problem I have. I have looked all over and cannot find a mounting location. I bought a "factory" type replacement but I have never seen one so that will help too. Thanks again.
Droff
Droff
Droff
Droff
On the swing arm there should be a tab with a hole in it. This is where the switch mounts.
To activate the switch, the brake lever is applied and the bolt on tab on the rod moves away from the switch, allowing the spring loaded button to come out and this switches on the brake light.
Let go of the pedal and it returns to home position and shuts off the brake light............ pg
As I said, the factory set up has a tab welded on the right side of the swing arm section, just in front of the right shock.
Many times a 'so-called customizer' will cut off this tab in an attempt to 'clean up the frame'............. pg
IMO trash them; order the ones from KC International, KCINT on eBay. $169 plus shipping. These are the very best forward controls for 1957 to 1974 XLs. And you brake light switch will install correctly.
hey piniongear I am to the point were I am ready to mount the brake light switch. Can you show me a picture of what the bracket for the switch looks like. Someone cut the one off of my frame so I am going to have to make one and welded it on myself. Also would you include the distance of how far the tab is from either the back or the front of the swingarm. I think measuring from the back would be easier.
pg
