ironhead clutch
ironhead clutch
After a recess (due to a university senior project) of a few months, I started riding again. My ironhead '85 XLS is in great condition I'm almost the sole owner (the original one sold it w/ 3500 miles). Anyway, my bike has 59,150 miles and I noticed that the gas comsupntion has going up dramatically. I used to make 200 miles w/ 3.8 gallons (before the reserve) now is 160 miles. I suspect a slippery old (its the original)cluctch,
Any suggestions?
Thanks!
Any suggestions?
Thanks!
RE: ironhead clutch
like the others have said, check the other things first, before you go diving into the clutch, I would seriously look into the carb first, and things like plugs, adjust your pushrods, start with the simple things first, then when you have got all that checked out and it still gets poor gas mileage then you now know what is left to check, Thats what I would do,, just my 1 1/3 cents.
Daryl
Daryl
RE: ironhead clutch
I'll go ahead and add another 2/3 to make it an even 2 cents. Check tire pressure also. That won't be enough to cause the kind of numbers you're seeing but it will compound any other irregularities. Also, I would think that with a bad clutch, if you can notice bad milage, than you should also see much worse throttle responce under pressure, (to pass a vehicle on the Hwy or up hills).
Rich
Rich
Calvin2209
Welcome Area Only
06-05-2013 08:23 AM
fjm3rd
09-14-2009 10:50 PM
