Clutch Replacement
Old Mar 25, 2008 | 01:43 AM
Dru's Avatar
Dru
Default Clutch Replacement
I have been riding my 07 Streetglide since June of 2007. Have close to 12K miles on already.
Any ideas on when to replace the clutch?
And is there any particular brand to get?
Old Mar 25, 2008 | 01:51 AM
txfxstrider's Avatar
txfxstrider
Default RE: Clutch Replacement
Unless you are some kind of crazy rider, you will probably never need to replace the clutch. At least not in the first 100,000 miles. Keep it adjusted properly and don't worry about it.
Old Mar 25, 2008 | 01:54 AM
Arizona's Avatar
Arizona
I'm approaching 73,000 miles, original clutch, etc... Still going strong but in my case alot of freeway mileage, so probably varies depending onriding habitsand type of roads, etc.
Old Mar 25, 2008 | 07:41 AM
dog155's Avatar
dog155
You will know when it is time if you keep the bike that long.
Old Mar 26, 2008 | 08:38 PM
FLAMED96's Avatar
FLAMED96
Changed mine at 60,000 miles just because I thought it was time, measured the old and new and compared, old ones had about 4 thou of an inch wear on each plate, should of left it alone and saved the time and money.
Old Mar 26, 2008 | 08:53 PM
1Harleyrdr's Avatar
1Harleyrdr
If you want a better clutch go for the Barnett if you are looking for stock feel. Dont change it until it starts to fail. You will first notice it in 1 to 2nd shifts if you ride hard or if you take it a little easyyou will notice in 4 to 5th shifts at speed. Motor will sound like a centrifigual clutch coming in slowly bring rpms back down where they belong.
Old Mar 27, 2008 | 01:52 AM
Avmech97's Avatar
Avmech97
My 2000RG is approaching 113,000 miles now and have had no problems with the original clutch.[sm=biker2.gif]
Old Mar 27, 2008 | 06:58 AM
Peppa1's Avatar
Peppa1
As others have said.....if it ain't broke you don't need to fix it !!!!! IF the $$$$$ are burning a hole in your pocket I can spend them for you !!!
twoskies
Jan 13, 2013 11:01 AM
first dyna 07
May 10, 2012 09:04 PM
drspencer
13
Sep 24, 2010 01:09 PM
mike@nhca.us
Nov 2, 2009 11:15 PM
roadking1893
Jan 10, 2009 03:23 PM
