M8 design
M8 design
I'm curious about the M8 design. Does it have a pressed crank like the Twin cam or tapered built up crank like an Evo? Timkin bearing supported crank? Is the oil pump still mounted concentric to the crank? And what's the crank runout spec?
All they needed was a counterbalanced Evo with new heads.
I want a new bike however I'm not sold on the new design yet.
Received 14,178 Likes
By 1998 all the issues were sorted out with the Evo motors. Looking at the new design, with the single chain driven cam, pressed crank and no Timken bearings, it looks like a cheaper version of the evo.
Larger displacement, the four valve heads, cam grind, anti knock sensors and better ecm programming are making the M8 a stronger motor. The counterbalance is just icing. Makes me wonder what they've done with the compensator and primary chain tensioner on the new motors.
I want hyabusa smooth, Cummins diesel freight train pull and longevity, Harley style and comfort.
The following 4 users liked this post by bad tappets:
