Anyone doing the breather bypass on your M8?
Old 11-28-2016, 09:01 PM
ron1026's Avatar
ron1026
ron1026 is offline
Welcome aboard Mr Bryce, Your experience and knowledge is appreciated.
Ron Baumer
16Slim (12-02-2018)
Old 11-29-2016, 08:15 AM
bradn's Avatar
bradn
bradn is offline
Originally Posted by CR3999
Pull the stock hoses off and throw away.
route to ground or install a catch can. Looking at the SE AC there will be some drilling the backing plate as they they reuse the same bolts as the stock air box. Also the air box is a lot closer the jug. There's not enough room do install like the twin cams, as there isn't enough room.
This is the way I did the by pass. Your plan my vary.
Do you get any oil blowing back up on the bike from the outlet on the tube under the frame?
Old 11-29-2016, 08:28 AM
CR3999's Avatar
CR3999
CR3999 is offline
I haven't noticed any on the bike. I have reached down to see if there is any oil at the end of the hose, there is. And If I really looked I'm pretty sure there may be some under the bike, but if I can't see it, it didn't happen.
The following 2 users liked this post by CR3999:
bradn (11-29-2016), dgwv (10-24-2019)
Old 11-29-2016, 11:16 AM
Heloguy's Avatar
Heloguy
Heloguy is offline
I read somewhere that the new M8 engines vent into the transmission. Basically eliminating the need to do this mod.
I hope I didn't misread that.
Old 11-29-2016, 11:50 AM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
You did not misread that. you are correct in what you read, that it vents to the trans., but it does not mean everything you read is correct.
TexasMotorcycleRider (03-31-2021)
Old 11-29-2016, 03:23 PM
bradn's Avatar
bradn
bradn is offline
Sooooo, which part is incorrect?
Old 11-29-2016, 03:28 PM
GlidingJoe's Avatar
GlidingJoe
the fact that you don't need to do it. HAHAHA
I know when they did the tear down on mine for my 117" kit at 800 miles, the cylinder already showed signs of oil being introducing into the combustion chamber burnt into the top of the piston
FLAGLIDIN (12-15-2021)
Old 11-29-2016, 03:54 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
I didn't read the same article so I can't say but in the M8 oil vapor from the breather on the top of each cylinder does indeed find its way into the air cleaner housing. Whether or not you feel the need to vent that to atmosphere, or catch can, or pavement is entirely up to you.
Old 11-29-2016, 04:08 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,260 Likes on 3,630 Posts
He read what was written correctly but what he read wasn't correct..
Old 11-29-2016, 04:37 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
I read a couple of those articles that got it wrong, what I think they did was misunderstand that the Oil return from the heads travels through a passage in the trans case to get back to the oil pan.
I ran external on my Twincam, Witness what comes out of the breather hose, its mostly condensation [ water] and some snot. there is no way in hell you can dump that mix of oil and condensation into the transmission.
I ran external after installing a S&S tear drop on my twincam, that cleaner did a poor job of directing blowby into the module, it all ended up on the filter bottom and kept dripping, I had a routine of wiping it off with my finger every time I stopped and onto my pants leg. here is a pic of that breather.
I am not concerned with my M8, I dont think it hurts the engine at all. but if it drips, I will address it for that reason.
Attached Thumbnails Anyone doing the breather bypass on your M8?-20160521_134002.jpeg   Anyone doing the breather bypass on your M8?-20160522_112144.jpeg
The following 3 users liked this post by sixguns:
FLHTK2015 (06-29-2022), M Oclaf (06-30-2022), sbeamer (12-09-2019)
Quick Reply: Anyone doing the breather bypass on your M8?
