PSA: Don't buy a Craftsman jack
So I was browsing Sears today looking for tools to piece together my new bike tool kit and I saw that they had their Craftsman jacks on sale for $100. I was holding out on some money from a TAD trip I took so I could buy a J&S jack but I figured I'd save some money and pick up one of these. I get it home, assemble it, and it won't fit under the bike. Even with the bike straight up the jack is too high. I measured and on the jiffy stand the frame is about 4 1/2" off the ground. The jack is 5 1/4" high. So I disassembled it and will be returning it tomorrow. Guess I'll be getting a J&S after all.
Craftsman or Craftsman pro(yellow)?
Im guessing not pro...
I have the pro and it works great.
http://www.sears.com/craftsman-profe...p-00950191000P
load97 (04-29-2018)
mastergunnera8 (12-30-2016)
If you don't want to return it, there are a number of threads on this forum that tell you how to modify the red craftsman jack to fit under all but the lowest Harley. All for about $10.
I also forgot to mention that you can roll your bike up in a 1 inch thick piece of wood and the jack should roll right under since you only lack 3/4 inch for clearance.
BigDogIdaho (12-31-2016)
You do have an option since it appears you are dealing with about 3/4" of space and that is to get a small piece of wood 3/4" and roll front and rear wheels on it to give your bike that extra height to allow the jack to roll under.
If you dont use the jack very often that may be a workable solution. For me I would see it as a pain in the *** as I would think it would require an extra set of hands each time you use the jack. One person to hold the bike steady and upright on the blocks unless you use a 3rd bock under the jiffy stand and the 2nd person to place the jack.
For me that is one of the great things about the J&S with the bike on the jiffy stand I just slide the jack underneath and jack it up off the jiffy stand. Its the same lowering the bike I just slowly lower the bike until it comes down and rest on the stand. I never have to touch or steady the bike in any way when I lift or lower.
On a side note I have found that after buying the J&S I use the jack way more than I even anticipated. Any time I want to wipe the bike down, detail it check air pressure etc... it is all much easier to do with the bike lifted and at eye level with me sitting on the stool
