VIN of the M8's w/ Engine Oil Pump problems
All it did was raise idle speed a bit. Going to put the bike to a good test starting May 26th. Wife and I will put between 3,600-4,800 miles on two up and loaded. It will get up to some high altitudes and some lower ones day, night ,wet ,dry , cool and hot . I only have 2000 miles on this one purchased it just as winter rolled in here. And I had been riding the sidecar a lot so it sat some this spring.
I am curious to know what the "VIN is on the 2017 M8 bikes that have had the Engine Oil Pump problems"?
I read somewhere that "supposedly" there was an Early Batch of Bad Engine Oil Pumps But, I have no actually spoken with my Dealer to verify this info.
I purchased my 2017 Road Glide Special in March & have about 500 miles on it so far, no Engine Oil Light has come on yet... Nothing abnormal that I can tell so far except, I do sometimes notice some kind of a noise at low speed But with all the echo that can go on from the Fairing and on back, I have Not been able to Isolate where the noise is coming from.
The last 8 of my VIN are: HB649429 - No Engine problems at this time.
Thank You
Thank You
I bought my bike the first week in October 16 so it's an early build. I've got just under 8k miles and no apparent problem with the oil pump or pressure so far. I would think what ever issue Harley had they likely wrapped their hands around it long before your bike came off the line.
Even with an early bike unless Harley issues a recall (hell will freeze over first) or a Technical Bulliten there's nothing to do other than ride my bike. In the absence of a documented serial number group of bikes from Harley anything else is just noise on the internet.
Mazz
Got word from the dealer, they have replaced the oil pump. As soon as they drop it off, I will test it to see if it smokes or if there is any more oil leaking from the rear cylinder/rocker cover. If it smokes when it starts, it goes right back to the dealer.
Thank you
FrankEGD
Thank you
FrankEGD
Thank You
Thank You
