Best $ 800 Farkle for your M8 - Ohlins Rear Shocks
I really think upgrading the forks is money and that is what makes the most difference in the ride. My total parts outlay was around $725. The difference is ridiculous...I really dont get why the cartridges cant come stock on other bikes than the low..The difference is like changing the stock boom system to an 8 speaker setup with amps..
I would have gone Ohlin or legend, but my budget wouldnt allow for front and rear and I wanted to do both at once....I am happy every time I ride it...which is daily...
If I had a 17 I would put cartridges in the front first and see how it rides..and go from there...
Ride safe all!!!
no, not kidding myself, have upgraded all my Harleys with aftermarket suspension because the stock ones all sucked..I kept the OEM's on my 2017 Road King because they are better than the Progressive 944's I had on my 2015 Road King. Same with the forks, as good as Progressive Monotube fork kit I have used before, no need to upgrade those again...when i ride my 2017 I don't ever think about the suspension, prior to now I couldn't think about anything else until I upgraded. I have no problem spending money on my bikes, if I felt for a second it was inadequate it would have been replaced immediately. My first set of Ohlins were on my 1978 Husky 250 when I was racing motocross starting back in the 1970's..I have a little bit of experience with motorcycle suspension over the last 40 years..
The following 3 users liked this post by mjwebb:
If you were into motocross at all as was I than you have probably talked to George at Pro Action. That is where I got the rears for my 2010. The 17 that I have sitting next to it in the garage has no where need the ride that the 10 has dispite endless fiddling. Both are late model frames. I thought I would give Ohlin's a shot this time around to give an apples to apples of pro action to Ohlin's and am awaiting their arrival. YYMV but I know that for me and especially the mrs. there is a substantial difference between the two.
I won't doubt that over the air shocks. Some can make them work but I never had much luck with them 2 up. Solo I could tolerate it. You also have the leaking air and having to carry a pump so I can see where you are coming from.
I am only 50 but riding my whole life so you have a few years on me because I wasn't fiddling with suspension at 10 years old as if it makes a difference. LOL
I understand where you are coming from but with your background you then understand that a good portion of the time when you add more spring the compression and rebound damping come into play. When we road MX our weight remained constant only the track conditions varied but all 3 adjustments still made a difference. Same went for track days on my sport bikes. Enter into the Harley world where our loads vary greatly sometimes as much as 200lbs more spring is needed to support the load and adjustments to the damping to compensate.
Where I am coming from is that the HD shocks with preload only are not in the same league as higher end shocks that are adjustable. Are they way better than the air shocks of the past yes.
^5 ! My first Husky was a 1968 360 8-Speed Desert Racer and it promptly got a set of Girling's suspenders on the back. After that one, a 1970 400 Cross (wish I had kept that one, aka the Steve McQueen / Malcolm Smith bike). then a 1973 250 CR Husky. They always got suspension improvements - what great bikes. I'm too old to race those anymore, but have fond memories of many an MX race and Hare Scrambles.
mjwebb (04-29-2017)
