Windshields?
Edit: I looked at your advice and figured I'd read some testimonials. Kind of hard to believe. Bordering on too good to be true. If I can wear a ball cap at 80 mph that would be darn near ideal. Don't like the look of the Klock flare though and that is a premium price for some heat molded plastic.
I really appreciate everyone's input so far. Keep em comming.
The stock shield is a 10" and I'm getting pegged mid nose & up. 90mph seems to be a sweet spot on these M8's so I'm looking for something to keep the bugs off and stop head buffeting. I just don't see how an 8" is going to help in my situation. I'm guessing our riding styles are a bit different. I updated my original post. Hope that helps.
I wear a ball cap occasionally and have no problem cruising 90+. I nearly always prefer my full face brain bucket though.
I'm 6' I swear by klockwerks shields super smooth cool look. I have the 8 and the 11.5 I use two different seats one stock amid one heated. Stock seat with 8 and heated I use 11.5 both dark tints... I've purchased no less then 10 shields for my Harleys finally I found klockwerks.... best shields I've owned... designed for racing on salt flats...
"I had that same exact thought when I asked the question. I'm mostly wanting to avoid the junk shields and limit my failed attempts. If I get very lucky I'll find someone here with the same goals when buying a shield. I'm thinking yours is the closest so far. Being 3" taller I'm thinking I might be happiest going for the 12" or I may be way off."
I'm 6'-2" as well and was experiencing the exact same as you with the 10" stock shield. I went with the Harley 12" and problem solved. It is contoured a little different from the stock and doesn't look as cool, but it works great. I ride mostly extended touring as well, and function/comfort trumps style very time.
Cheers,
Martin
Cheers,
Martin
Think I'm leanin this way. I don't need to spend another C note for the same results. Don't make sense to me.
